bobthebob1234 LXF regular
Joined: Thu Jan 03, 2008 9:38 pm Posts: 1356 Location: A hole in a field
Posted: Sat Feb 18, 2012 7:00 pm Post subject: Quickest way to copy 1tb of stuff from one hdd to another... |
over usb?
Copying videos from nas that has decided to reset its settings but has nicely formatted the hard drive(s) with ext3
So I want to plug nas hdd into myth box via sata->usb adaptor I have.
So what would be the quickest way to copy over this data. Ideally I would be able to set it off in the background but check its progress every now and then
So rsync, cp or Ctrl-C Ctrl-V from desktop (Thunar file manager) _________________ For certain you have to be lost to find the places that can't be found. Elseways, everyone would know where it was |
ajgreeny LXF regular
Joined: Wed May 10, 2006 9:18 pm Posts: 407 Location: Oxfordshire.
Posted: Sat Feb 18, 2012 9:56 pm Post subject: |
Can you just drag and drop in thunar? Actually, I think rsync may be easiest, and can be left to run in the background where you can check occasionally. _________________ Ubuntu 10.04 user, and loving it! |
Posted: Sat Feb 18, 2012 10:13 pm Post subject: |
Well you can copy and paste in thunar cos I just did it for 160gb of stuff... Took its time though _________________ For certain you have to be lost to find the places that can't be found. Elseways, everyone would know where it was |
wyliecoyoteuk LXF regular
Joined: Sun Apr 10, 2005 11:41 pm Posts: 3358 Location: Birmingham, UK
Posted: Sat Feb 18, 2012 10:56 pm Post subject: |
Any way that you copy 160Gb over USB is going to take a while.
At least it will complete, which would be dubious on windows drag'n drop. _________________ The sig between the asterisks is so cool that only REALLY COOL people can even see it!
nelz Moderator
Joined: Mon Apr 04, 2005 12:52 pm Posts: 7999 Location: Warrington, UK
Posted: Sun Feb 19, 2012 11:38 am Post subject: |
Stick with rsync, because you can restart the transfer if needed. The hardware will be the speed limit here, not the software you choose, but rsync is the most reliable of the alternatives, and gives the most faithful copies. _________________ Unix is user-friendly. It's just very selective about who it's friends are. |
Dutch_Master LXF regular
Posted: Sun Feb 19, 2012 12:35 pm Post subject: |
+1 on rsync...  |
Posted: Mon Feb 20, 2012 1:02 pm Post subject: |
Well rsync is off and running. Only 40 hours to go... _________________ For certain you have to be lost to find the places that can't be found. Elseways, everyone would know where it was |
