Weatherlawyer
Joined: Fri Nov 27, 2009 2:24 pm Posts: 53 Location: Stoke on Trent, England.
Posted: Fri Feb 24, 2012 10:48 am Post subject: Audio codecs |
I have an Asrock P4 i65G I need audio codecs for. All the home page supplies is M$ Windows crap.
What can I do about it. _________________ I would very much like to be nice. If this is not your day, I am sorry about that. |
dandnsmith LXF regular
Joined: Fri Apr 15, 2005 11:01 am Posts: 269 Location: Berks, UK
Posted: Fri Feb 24, 2012 11:26 am Post subject: |
First, say what distro you're talking about.
Second, are you sure it's codecs you want - usually you go to the manufacturers page for drivers, but to other sources for codecs (depends what exactly you want to decode).
If it's Linux of some sort (I presume it is), then drivers will normally get supplied on load.
Codecs can be got either by consulting the repositories or by downloading a complete player package. _________________ Derek |
wyliecoyoteuk LXF regular
Joined: Sun Apr 10, 2005 11:41 pm Posts: 3369 Location: Birmingham, UK
Posted: Fri Feb 24, 2012 12:47 pm Post subject: |
Chipset on that mobo is a Cmedia 9761A.
Should be supported by almost any distro. _________________ The sig between the asterisks is so cool that only REALLY COOL people can even see it!
Weatherlawyer
Posted: Fri Feb 24, 2012 5:12 pm Post subject: Solved thanks. |
Thanks to both prompt repliers.
The supplier or the Mother-board produced seems to offer a choice of Windows downloads as if they were the only chips in the shop.
I have had this problem with most of the cover discs I have used. This one is the Ubuntu 10.10 and upgraded from Ubuntu website yesterday. If they have sound drivers, how do I access them?
I thought the driver was a Realtek AC97 codec so I went and got that just now. Not sure I have installed it right. But I will get the other one if possible.
I had the impression CAudio was a M$ thing. I always ended up with RealTek player when I had to get drivers for XP in times past. C Audio always seemed to bork it.
Anyone know the best sound card to get for Linux distros?
One with a CD or whatever that has an alternative to M$fud
edit:
That seems to haver caught it.
What are the default settings on audio devices on your discs and how do I get around in them? _________________ I would very much like to be nice. If this is not your day, I am sorry about that. |
lok1950 LXF regular
Joined: Tue May 31, 2005 6:31 am Posts: 959 Location: Ottawa
Posted: Fri Feb 24, 2012 8:35 pm Post subject: |
Drivers in Linux are part of the kernel and choosing which one to use is usually done by the hardware detection routines that are part of the installer and the normal start up scripts that will detect new hardware.
Enjoy the Choice  |
ajgreeny LXF regular
Joined: Wed May 10, 2006 9:18 pm Posts: 413 Location: Oxfordshire.
Posted: Sun Feb 26, 2012 9:39 pm Post subject: |
Is your problem solved or not; I can not tell from your last post.
If not try using in terminal and check that the levels of outputs are not set too low.
Move from slider to slider, and raise and lower levels with the cursor keys;
Mute and unmute with the "M" key.
Tab will move you from "playback" to "capture".
Esc will save and exit. _________________ Xubuntu 12.04 user, and loving it! |
Weatherlawyer
Posted: Fri Mar 09, 2012 12:46 am Post subject: |
I was too embarrased to reply but |I have got over it now.
The sound was set to mute on the pull down preference. I don't know how that happened but it sometimes goes like that on the sound control on You Tube videos too.
I don't know what of all the choices I should make about the hardware settings too neither.
I have a couple of speakers with a bass woofer whatsit and a pair of ear muff/mic thingumies that don't record very well.
I'm not at all delighted with things but they are working~ish, so far.
I'm going to try the codec suggested and thern the last bit of advice. Thanks all. _________________ I would very much like to be nice. If this is not your day, I am sorry about that. |
Weatherlawyer
Posted: Fri Mar 09, 2012 12:50 am Post subject: |
| wyliecoyoteuk wrote: | Chipset on that mobo is a Cmedia 9761A.
Should be supported by almost any distro. |
P4i65G
Drivers
Driver OS Size Description Download From
AMR Windows® 98
2.80MB AMR driver ver:12.0300.0018 Download from Asia server
Asia Download from Europe server
Europe Download from USA server
USA Download from Asia server
China
AMR Windows® ME
2.78MB AMR driver ver:12.0300.0018 Download from Asia server
China
AMR Windows® 2000
Windows® XP
2.61MB AMR driver ver:12.0300.0030 Download from Asia server
China
Audio Windows® 98
Windows® ME
Windows® 2000
Windows® XP
25.16MB C-Media AC97 audio driver ver:Integrate003 Download from Asia server
China
HDMR Windows® 98
1.94MB HDMR driver ver:7.35.00 Download from Asia server
China
HDMR Windows® 2000
Windows® XP
China
HDMR Windows® ME
1.83MB HDMR driver ver:7.35.00 Download from Asia server
China
INF Windows® 98
Windows® ME
2.49MB INF driver ver:6.3.0.1007 Download from Asia server
China
INF Windows® 2000
Windows® XP
677.72KB INF driver ver:7.0.0.1025 Download from Asia server
China
Lan Windows® 98
Windows® ME
Windows® 2000
Windows® XP
2.30MB Realtek Lan driver ver:621 Download from Asia server
China
USB> Windows® 98
Windows® ME
1.12MB Intel USB 2.0 driver ver:1.1.0.2 Download from Asia server
China
VGA Windows® 2000
Windows® XP
4.94MB VGA driver ver:14.17.0.4396 Download from Asia server
China
VGA Windows® 98
Windows® ME
6.95MB VGA driver ver:13.6.1.3732 Download from Asia server
China
http://www.asrock.com/mb/download.asp?Model=P4i65G&o=All
So I won't be using that. Though I should get a bios flash I suppose. _________________ I would very much like to be nice. If this is not your day, I am sorry about that. |
Weatherlawyer
Posted: Fri Mar 09, 2012 12:59 am Post subject: |
| ajgreeny wrote: | | Try using in terminal and check that the levels of outputs are not set too low. |
How? _________________ I would very much like to be nice. If this is not your day, I am sorry about that. |
lok1950 LXF regular
Posted: Fri Mar 09, 2012 1:34 am Post subject: |
There is an app called a terminal for working on the command line text input and output no graphics Just copy/paste
[ into it and hit enter the mixer will run in the terminal using a ncursres interface that you use the keyboard to navigate and aj said check the levels for each channel.
Enjoy the Choice  |
