Password and printer problems
tonyfromardleigh
PostPosted: Thu Apr 12, 2012 7:52 am    Post subject: Password and printer problems Reply with quote
I am new to linux having just installed Ubuntu 11.10 on my PC which also has Vista as a dual boot. I have 2 overlapping problems. When I installed Ubuntu I provided a password for my user - the only user for this OS. I decided I didn't need a password and removed it. Now when asked to authenticate actions I can't. It won't work whether I put my password in or just press enter. Means I can't change anything Sad
I have a fairly standard Canon printer (Pixma ip4200). Ubuntu has detected my printer and correctly identified it but won't print anything. The printer dialog box shows the printer as "paused". I can't unlock the dialog box because of the password problem above.
I suspect I will need to go into root or the command line to fix this neither of which I have done. Don't know what the root password is...
PostPosted: Thu Apr 12, 2012 8:58 am    Post subject: Reply with quote
This may help:
http://www.psychocats.net/ubuntu/resetpassword
If you are a dual booter, this tool may come in handy in the future
http://www.supergrubdisk.org/rescatux/
tonyfromardleigh
PostPosted: Thu Apr 12, 2012 4:56 pm    Post subject: Reply with quote
The password work round didn't work! Having looked around the internet it seems that Ubuntu locks the root. When I tried to login as root I was prompted for a password... I wouldn't let me use sudo at the command prompt either.
I have reinstalled Ubuntu and it now works fine. Although I haven't done anything different the printer now works Smile
I now have 2 copies of Ubuntu on my hard drive, one of which is very limited. I suppose I ought to delete it...
PostPosted: Thu Apr 12, 2012 5:16 pm    Post subject: Reply with quote
the printer probably failed because the Linux printing system expects an authenticated user (empty password is a nono)
PostPosted: Thu Apr 12, 2012 5:51 pm    Post subject: Reply with quote
Setting up a user with no password is a bad idea, and sudo won't allow such a user to perform administrative tasks. If you don't want to type in a password when you login, set up auto-login for the desktop. Then you'll only need your password for adminstrative tasks.
It's a bit late now, but you didn't need to reinstall to fix this, you can rest the password from a live CD. Mount your Ubuntu partition, say at /mnt/ubuntu, and run
Code:
passwd --root /mnt/ubuntu yourusername
tonyfromardleigh
PostPosted: Thu Apr 12, 2012 5:56 pm    Post subject: Reply with quote
Thanks guys. A case of all that ends well...
I didn't realise that no password would cause such problems and Ubuntu willingly offered the option with no warning of the dire consequences.
PostPosted: Thu Apr 12, 2012 11:54 pm    Post subject: Reply with quote
I don't think Ubuntu offered the option; you were the one that removed the password weren't you?
As the old saying goes: the guy representing himself in court has a fool for a client Rolling Eyes
PostPosted: Fri Apr 13, 2012 4:32 pm    Post subject: Reply with quote
Think of it as an example of the basic differences between Linux and Windows.
Windows will let anyone mess with your stuff, Linux expects you to act responsibly.
A password is the minimum you should protect your PC with:)
That basic protection is part of the reason why it can actually be quite difficult to catch a virus on Linux.
