RoosterMan
Joined: Mon Jan 16, 2012 2:38 am Posts: 14 Location: California
Posted: Fri Apr 13, 2012 4:55 am Post subject: KDE 4 Kubuntu Oxygen Transparent Help |
So, I've been trying to install "oxygen-transparent" for KDE. I get this error:
| Code: |
--- oxygen transparent easy setup script
--- checking out source code
git clone git://anongit.kde.org/oxygen-transparent
sh: git: not found
system git clone git://anongit.kde.org/oxygen-transparent>&1 failed: 32512
I am on Kubuntu 11.10. Thanks! |
lok1950 LXF regular
Joined: Tue May 31, 2005 6:31 am Posts: 958 Location: Ottawa
Posted: Fri Apr 13, 2012 5:25 am Post subject: |
Do you have git installed as well as build-essentials as you are building it from the source code that git will download
Enjoy the Choice  |
RoosterMan
Posted: Fri Apr 13, 2012 7:10 am Post subject: |
So I installed git and got a lot further, but I still don't think it worked. I don't know if I have these. I am on OpenSUSE now, and don't know how to translate the command (or if I need to)
| Code: | | sudo apt-get install build-essential cmake kdelibs5-dev kdebase-workspace-dev libxrender-dev libx11-dev subversion |
Of course, I am still unsure of exactly how to use it...
http://kde-look.org/content/show.php?content=127752
Should I post my console output? |
lok1950 LXF regular
Posted: Fri Apr 13, 2012 3:39 pm Post subject: |
Not sure myself I'm a fedora user but is there not a software installer app in OpenSUSE use it to install the following
| Code: | - gcc-c++
- git
- cmake
- kdebase-workspace-dev
- libxrender-dev
- libx11-dev
the command quoted is for Debian based distros which used .deb's not .rpm's
Enjoy the Choice  |
Ram LXF regular
Joined: Thu Apr 07, 2005 10:44 pm Posts: 1550 Location: Guisborough
Posted: Fri Apr 13, 2012 4:38 pm Post subject: |
openSUSE uses YaST for package installation. _________________
lok1950 LXF regular
Posted: Fri Apr 13, 2012 6:10 pm Post subject: |
Thx for chiming in Ram though I kinda expected Rhakios as he is also a OpenSUSE user
Enjoy the Choice  |
Rhakios Moderator
Posted: Fri Apr 13, 2012 7:33 pm Post subject: |
| lok1950 wrote: | Thx for chiming in Ram though I kinda expected Rhakios as he is also a OpenSUSE user
Am I? I thought I'd been using K/X/Ubuntu 10.04 since it came out. Still, zypper is the CLI tool for in stalling packages on openSUSE. As in
zypper install package1 package2
and so on.
Using zypper search is quite as good as apt-cache search for finding out the relevant correct package names. _________________ Bye, Rhakios |
