Flash problem? SOLVED
PostPosted: Sat Apr 14, 2012 11:49 am    Post subject: Flash problem? SOLVED Reply with quote
I saw "The Cabin in the Woods" last night. I liked it and mentioned it on facebook to a friend of mine. He hadn't heard of it, so I posted a link to a youtube trailer for it. I checked the link and realised the colour was all messed up. People looked like the cast of avatar! Shocked
It seems not all vids are affected. My youtube vids are unaffected, as are some others, but it seems that most of the Hi-Def trailers are.
Some people are of the opinion it's to do with the latest version of flash. I tried disabling it and installing gnash, but I couldn't find it on the FF add-on options.
Any ideas?
****edit****
Here's the link I posted. Hope it helps.
http://www.youtube.com/watch?v=7ENUBUdFswM
AMD PHENOM II X6, 14 GB DDR3, 500 GB hd, 1GB nVidia card, running Linux Mint 14 KDE / Win 7. Damn thing keeps breaking.
eeepc 1015PX, 1.66 Ghz Intel atom processor, 2 GB DDR3, 320 GB hd running Mint 14 MATE. Running great.
roseway
PostPosted: Sat Apr 14, 2012 2:12 pm    Post subject: Reply with quote
It looks fine here, using the latest version of Flash (11.2.202.233, just released).
Eric
PostPosted: Sat Apr 14, 2012 2:28 pm    Post subject: Reply with quote
I use chrome browser and that link works fine without the need for blooming flash Twisted Evil
Having said that I pasted the address into Firefox and it works fine on there too Wink
PostPosted: Sat Apr 14, 2012 3:21 pm    Post subject: Reply with quote
I still have the problem on both FF and Chromium... Shocked
PostPosted: Sat Apr 14, 2012 3:23 pm    Post subject: Reply with quote
Ah, I'm using .228 rather than .233.
Any idea how to force the update?
roseway
PostPosted: Sat Apr 14, 2012 7:35 pm    Post subject: Reply with quote
That depends on what distro you use, and how you installed Flash. I use Debian Testing, and Flash is installed with a package called flashplugin-nonfree. This is a helper package which downloads the latest version of Flash from Adobe and installs it. I uninstalled this package and reinstalled it to get the latest version.
Eric
PostPosted: Sat Apr 14, 2012 9:51 pm    Post subject: Reply with quote
Works for me and I'm still using .228
ajgreeny
PostPosted: Sat Apr 14, 2012 11:03 pm    Post subject: Reply with quote
I have just downloaded the flash tar.gz from adobe and extracted the libflashplayer.so from it just to try it out. I then copied this new version 11.2.202.233 to replace the 11.1r102 which had been the last that worked on my machines, and much to my surprise it worked with no problems.
The 11.2.202.228 previously available had not worked at all in my systems.
EDIT:
I spoke too soon. The problem is still there on my main desktop with ATI 9200SE graphics card, so now back to 11.1r102.
PostPosted: Fri Apr 20, 2012 10:27 am    Post subject: Reply with quote
Fixed it. Right click on video, select settings and untick "hardware acceleration". Then refresh. Problem solved.
PostPosted: Fri Apr 20, 2012 1:41 pm    Post subject: Reply with quote
I have HW acceleration ticked.
Lanser
PostPosted: Fri Apr 20, 2012 4:05 pm    Post subject: nvidia Reply with quote
I had this issue too, apparently only happens with nVidia graphics
PostPosted: Fri Apr 20, 2012 4:45 pm    Post subject: Re: nvidia Reply with quote
I have a NVidia 8800 GTS
PostPosted: Fri Apr 20, 2012 4:47 pm    Post subject: Reply with quote
I have a nVidia card. Not sure which one. It's a 1GB one.
