Mandriva 2008 Free
Goto page Previous  1, 2, 3
Post new topic   Reply to topic    Linux Format forums Forum Index -> Magazine and coverdiscs
Goner
PostPosted: Fri Feb 01, 2008 9:54 am    Post subject: Reply with quote
Marrea wrote:
I can tell you one thing - to be a Mandriva user you surely have to be a glutton for punishment !! Wink
Yeah, it's a bit of a challenge sometimes ...
But it pays off ; installing the Nvidia drivers (OpenGL) now also allows me to run GoogleEarth !!
Looks great ...
Still struggling with 'Enemy Territory: Quake Wars' ; the game runs fine, but after some time the keyboard becomes 'unresponsive'. Right at the beginning I got a pop-up from Mandriva telling me that keeping 'Shift' pressed for longer than 5 secs. is some kind of option for 'disabled persons' or something like that. I cancelled it, but now wonder if something happened ...
Mmm ... http://forum.mandriva.com/viewtopic.php?t=75014
Aha ... http://www.openfree.org/forums/showthread.php?t=17516
Marrea
PostPosted: Sat Feb 02, 2008 9:53 pm    Post subject: Reply with quote
Just to let you know that I find I can now change the look of my clock and it sticks even after a reboot. I don't know whether one of the updates has brought this about or not. It could just be one of those little unexplained Linux idiosyncrasies I suppose. Confused
I have also managed to solve the "urpmi database locked" problem I referred to above by simply getting rid of the update applet with:
Code:
# urpme mdkonline
This means of course I shall have to do my updating manually, but I'd rather have that than be hampered by an inexplicable locking of the database.
PostPosted: Sun Feb 03, 2008 1:10 pm    Post subject: Reply with quote
Marrea
I might have a look, but Mandriva, which used to be such fun, hardly seems worth it to me these days.
I don't think this is the first time there have been problems with mdkonline either. Did it lock the rpm database permanently, or merely while it took (an excessive) time to fetch update info.
On openSUSE, there's no point in looking at installing packages while the updater is doing its thing, odd that it usually chooses to about the time I'm thinking of installing some new packages. Rolling Eyes
Marrea
PostPosted: Sun Feb 03, 2008 3:38 pm    Post subject: Reply with quote
Once locked, it would indeed remain permanently locked.
I'd boot into Mandriva, it would do its searching, tell me there were updates, which I would then install. After that I would carry on working, typing documents, surfing the net, etc. and then suddenly notice that the icon had changed to orange with a question mark. Hovering the mouse over would give the database locked message. It would then remain like that, even if I rebooted, which meant I couldn't use Install and Remove Software to install anything.
The next day I'd boot in, it would do its searching, show the green tick icon and all would appear to be well. However, after a while, for no apparent reason, the icon would change to the question mark again.
I thought to myself, here we go - SuSE 10.1 all over again!
However I have decided to persevere with Mandriva this time instead of (as I have usually done in the past) giving up at the first hurdle, which in this case was the hosing of the MBR during installation. Wink
Goner
PostPosted: Mon Feb 04, 2008 10:14 am    Post subject: Reply with quote
hi,
I just allowed Mandriva Online to get the updates for the first time since installation. There were about 157 entries in the list, guess that's normal first time, and everything went fine (green checkmark icon). I notice that the mdkonline package description mentions 'registered users' but I never registered (yet) ... ??
I configured repositories thru the media manager (official updates & distribution sources) and also on Easy Urpmi (http://easyurpmi.zarb.org/).
EDIT:
the bad news is that after restarting, all of a sudden the default (1st) entry of Grub now starts a command-line Linux !! GUI (KDE) is gone ... !?
Entry is now :
linux (/boot/vmlinuz-desktop)
and there are 2 new entries :
desktop 2.6.22.9-1 (/boot/vmlinuz)
desktop 2.6.22.12-1 (/boot/vmlinuz-2.6.22-12-desktop-1mdv)
the first one gives me the old KDE ...
1 more of these features and I'm switching to Ubuntu ... Sad
Goner
PostPosted: Mon Feb 04, 2008 7:51 pm    Post subject: Reply with quote
Looks like I locked myself out of Linux ... thought I would edit /boot/grub/menu.lst to get rid of the unwanted menu items and now all I get is a black screen with 'GRUB' in th upper-left corner.
Think I'm gonna give Mandriva a miss until I feel more masochistic ... Sad
Marrea
PostPosted: Mon Feb 04, 2008 9:07 pm    Post subject: Reply with quote
Goner
I would hazard a guess that your problem was something to do with one of your updates being a kernel update - which requires the reinstallation of your nvidia driver afterwards. And before the driver will reinstall you would have to go through the edit to the /usr/src/linux/Makefile that you did before - but this time changing the EXTRAVERSION line to match the updated kernel.
Unfortunately now you have edited menu.lst I am not quite sure where this leaves you. I don't know whether Rhakios (or anyone else) can offer any advice here. I'm no expert on video drivers I'm afraid.
In case it helps, here is my current Mandriva menu.lst after updating my kernel a few days ago:
title linux
kernel (hd0,1)/boot/vmlinuz-desktop BOOT_IMAGE=linux root=/dev/hda2 resume=/dev/hda6 splash=silent vga=788
initrd (hd0,1)/boot/initrd-desktop.img
title linux-nonfb
kernel (hd0,1)/boot/vmlinuz BOOT_IMAGE=linux-nonfb root=/dev/hda2 resume=/dev/hda6
initrd (hd0,1)/boot/initrd.img
title failsafe
kernel (hd0,1)/boot/vmlinuz BOOT_IMAGE=failsafe root=/dev/hda2 failsafe
title windows
root (hd0,0)
makeactive
chainloader +1
title desktop 2.6.22.9-1
kernel (hd0,1)/boot/vmlinuz BOOT_IMAGE=desktop_2.6.22.9-1 root=/dev/hda2 resume=/dev/hda6 splash=silent vga=788
title desktop 2.6.22.12-1
kernel (hd0,1)/boot/vmlinuz-2.6.22.12-desktop-1mdv BOOT_IMAGE=desktop_2.6.22.12-1 root=/dev/hda2 resume=/dev/hda6 splash=silent vga=788
initrd (hd0,1)/boot/initrd-2.6.22.12-desktop-1mdv.img
PostPosted: Mon Feb 04, 2008 9:40 pm    Post subject: Reply with quote
I thought nelz was the resident grub expert. If you get a grub prompt, you can boot the system by inputting the details manually, I'm sure nelz will be along soon to tell you exactly how.
If you want to modify the bootloader at a later date, it would be a good idea to use the tool in Mandriva Control Centre, as it will make it slightly more difficult to mess things up.
Of course, uninstalling old kernel packages (as long as you know the new kernel is functioning as desired) will also remove their entries from grub, in my experience.
Goner
PostPosted: Tue Feb 05, 2008 9:40 am    Post subject: Reply with quote
That's exactly how my menu.lst looked (after the updates).
I saw some kernel-devel & kernel-source packages in the liist of update/patches, but did not think it would actually update the working kernel itself.
When the first entry only gave me a command-line, I tried some of the others and the 5th (title desktop 2.6.22.9-1 ) booted me into my 'old' Mandriva !!
So I thought I could just change the 1st entry back to 'initrd (hd0,1)/boot/initrd.img', but that did not work.
Btw, I did try the boot config tool in Control Centre first, but it does not let you change the 'initrd' lines.
Goner
PostPosted: Tue Feb 05, 2008 3:26 pm    Post subject: Reply with quote
OK, just did a fresh install of Mandriva 2008 ... I gues I'm one of those 'gluttons for punishment'.
Of course it trashed the MBR again (and guess what, Fix Windows Root in the Mandriva Rescue mode does not - fix it that is).
Marrea,
>Rebooted (don't know whether you have to do this or not, but I did) and ran
>sh NVIDIA-Linux-x86-169.07-pkg1.run
>and this time it installed OK.
which extra packages did you have to install for that ?? I remember I had to get both kernel-devel and kernel-source for the installer to compile correctly. is that right ?
Hima
PostPosted: Tue Feb 05, 2008 7:18 pm    Post subject: Reply with quote
my friends i'm sure that you are very good in that way
thanks alot for your help
Marrea
PostPosted: Tue Feb 05, 2008 9:31 pm    Post subject: Reply with quote
Goner wrote:
Marrea,
Goner
Originally my kernel was 2.6.22.9-desktop-1mdv. Prior to trying to install the nvidia driver I installed kernel-source-2.6.22.9-1mdv and also kernel-desktop586-devel-2.6.22.9-1.mdv. I don't know whether the devel package is necessary for the purposes of the nvidia driver but I installed it anyway! The kernel-source package is definitely needed.
The driver wouldn't install successfully until I followed Rhakios's instructions about editing the Makefile in /usr/src/linux (as laid out earlier on in this thread).
Then after updating my kernel a few days ago to 2.6.22.12-desktop-1mdv I first edited the Makefile again to take account of the new version number, followed by a reinstallation of the nvidia driver.
That's interesting. I reported the problem about my MBR being overwritten over on the Mandriva Users Forum and was told:
"First of all, you do not need the XP CD in order to restore the XP Bootloader. The Mandriva CDs/DVD do(es) have a rescue option which allows to restore the XP or Grub bootloader with two clicks."
Apparently, from your experience, it does not!!
I was also told on the same Forum:
"I am sorry to say it but you are incorrect about not being able to determine where the bootloader is placed in the initial segment that applys to the bootloader.
It simply means that you did not set it up correctly."
Hmm, yes, well. So now I know - it's all my fault, not Mandriva's at all. Wink
Goner
PostPosted: Tue Feb 05, 2008 10:50 pm    Post subject: Reply with quote
OK, thanks!
I am about to install the Nvidia driver. Looks like only the kernel-source is needed as installing that package creates the /usr/src/linux folder and the Makefile.
Latest version is 2.6.22.9-2mdv, so I changed the Makefile accordingly (might try 2.6.22.12 later when I feel really brave).
About the Mandriva rescue option ; it detected a Grub on /sda (MBR) and /sda5 (Linux EXT3 partition), so I told it to fix the /sda and 2 clicks and a reboot later, nothing had changed ...
Also it looks like the installation first by default installs Grub on the MBR and then later (in the Summary) asks where it should be installed and then installs Grub again ... but the MBR remains trashed.
OOPS! : had to install kernel-source-2.6.22.9-1mdv, not -2mdv !!
Goner
PostPosted: Fri Feb 08, 2008 9:18 am    Post subject: Reply with quote
Well, with the lessons learned the 2nd installation was a success ... spending more & more time in Linux!!
Any suggestions for useful software to install ??
Installed so far:
- Nvidia 169.09 drivers and Enemy Territory:Quake Wars (main reason to install Linux)
- Google Earth
- Thunderbird & ntfs-config/ntfs-3g to symlink the Mail folder already on Windows NTFS partition for reading/writing.
Does anybody know if one of the older Sun Java's will work with Firefox ? As mentioned 1.6 is a bit of a problem.
jalanb
PostPosted: Sat Sep 20, 2008 5:08 am    Post subject: Reply with quote
Rhakios wrote:
I had a similar problem compiling VMWare tools on Mandriva, what I did was to edit the Makefile in /ur/src/linux to say:
EXTRAVERSION = .12-desktop-1mdv
Then I ran:
make oldconfig
make modules_prepare
make prepare
Thank you, works for me when installing cisco vpn
Alan
Post new topic   Reply to topic    Linux Format forums Forum Index -> Magazine and coverdiscs All times are GMT
Page 3 of 3
