dickiemint5
Joined: Tue Apr 28, 2009 5:09 pm Posts: 6 Location: Gloucester
Posted: Tue Feb 23, 2010 2:44 pm Post subject: DEFT - rkhunter - rootkit search on windows machine |
Hello. Is there a way of pointing rkhunter, as found on the DEFT live cd, to search on the 'C' partition of a windows machine?
rkhunter is CLI driven, and I am next to useless at the command line. The same cd has clamtk as a windowed front end to clamav, which I can get to work fine.
In other words, command line help for rkhunter please.
Cheers
Dick |
nelz Moderator
Posted: Tue Feb 23, 2010 3:08 pm Post subject: |
No, because rkhunter is designed to test the currently running Unix-alike OS. You can have it check another supported OS with the --rootdir option, but not a Windows directory. _________________ "Insanity: doing the same thing over and over again and expecting different results." (Albert Einstein) |
dickiemint5
Posted: Tue Feb 23, 2010 4:56 pm Post subject: Thanks |
Thanks for that reply. Explains why I cannot do it then.javascript:emoticon(' ')
Do you know of anything that will search for rootkits on a machine which is NOT running is installed OS?
Cheers
Dick |
nelz Moderator
Posted: Tue Feb 23, 2010 7:23 pm Post subject: |
rkhunter will do that, but only for *nix OSes. Have you tried googling for Windows rootkit? _________________ "Insanity: doing the same thing over and over again and expecting different results." (Albert Einstein) |
dickiemint5
Posted: Wed Feb 24, 2010 8:32 pm Post subject: Windows rootkit finders |
Thanks again nelz. Yes I have tried, but it gets confusing. Tried a microsoft 'revealer', and did not know what I was looking at. Tried Prevexcsi, which told me I had a virus which was not!
I shall have to take time to learn how to make a simple ubuntu cd with at least Clamtk, so that I can virus check an OS without running same.
In case you are wondering, I look after a Vista 32bit PC, which was running happily for some 3 years with no faults. Then a month ago it started to go slow. I found that around 85% of its 1 GB ram was being used, and that swapping the page file to HD was slowing the machine down considerably. I suspect a virus, but AVG et al shows nowt.
But that is not a subject for this forum.
Thanks again for your replies.
Dick |
paulm LXF regular
Joined: Mon Apr 03, 2006 5:53 am Posts: 223 Location: Oxfordshire, UK
Posted: Wed Feb 24, 2010 9:52 pm Post subject: Re: Windows rootkit finders |
| dickiemint5 wrote: | | I shall have to take time to learn how to make a simple ubuntu cd with at least Clamtk, so that I can virus check an OS without running same. |
While doing so might be a good exercise from an educational point of view, in terms of what you are looking for, its a lot of unnecessary work
Download and burn a copy of SystemRescueCD:
http://www.sysresccd.org/Main_Page
That will give you everything you need not only to scan a M$ computer for virus problems, but to remove passwords, back up, rescue files from a non-booting M$ operating system, etc.
Anyone who has to deal with the endless problems Windows comes up with should not be without a copy....
I often find myself amused by the fact that people who will not look at Linux often owe the continued operation of their 'superior' Windows machine to Linux.
Paul. |
dickiemint5
Posted: Thu Feb 25, 2010 10:28 am Post subject: SystemRescueCD |
Thanks for replying. I currently use Mint 8 as a desktop machine for all 'office' and internet work, so I am not against Linux, but rather very much for it. It is the command line I always have trouble with, and most advice is given with a command line example, and these days my pensioner brain struggles!!!
I will now have a learning curve with System Rescue. Ah well, keeps the brain ticking over.
Again, thanks for the replies.
Cheers.
Dick |
towy71 Moderator
Joined: Wed Apr 06, 2005 3:11 pm Posts: 4176 Location: wild West Wales
Posted: Thu Feb 25, 2010 10:50 am Post subject: Re: SystemRescueCD |
| dickiemint5 wrote: | | ... I currently use Mint 8 | Then your user name must be a misnomer  _________________ still looking for that door into summer |
