Bazza LXF regular
Joined: Sat Mar 21, 2009 11:16 am Posts: 1381 Location: Loughborough
Fat_Tuesday
Posted: Thu Aug 26, 2010 11:44 am Post subject: |
| We're gonna need a bigger hard drive ... |
Dutch_Master LXF regular
Posted: Thu Aug 26, 2010 12:13 pm Post subject: |
With 2TB disks available for affordable prices and SSD on the verge of making it into the TB range, that problem will be solved before this device is available is a real product  |
Marrea LXF regular
Joined: Fri Apr 08, 2005 10:32 pm Posts: 1846 Location: Chilterns, West Hertfordshire
Posted: Thu Aug 26, 2010 1:13 pm Post subject: |
I shouldn't get too excited.
From the PC Pro site:
However, those expecting an enormous boost in image resolution in the near future are set to be disappointed. The company unveiled a 50-megapixel CMOS sensor in 2007, but that has yet to arrive in a DSLR.
"While we have no plans for a consumer product [containing the 50-megapixel sensor], we are looking at it for commercial products," a Canon spokesperson told PC Pro, with medical imaging devices among the likely uses.
By Bureaunet on 24 Aug 2010
At that sort of resolution (which unquestionably has a use, commercially) the biggest problem is the resolving power of lenses, which at today's optical standards simply won't cut the mustard.
By PaleRider on 24 Aug 2010
It is difficult to see how such a sensor might be used, since as Bureaunet correctly says, lenses currently cannot resolve to such a fine level. Glass lenses are never likely to be able to either. Today's 20+MP cameras are already stretching lenses.
Quite frankly, what would make me go "Wow" is if the camera manufacturers concentrated on solving the problem of sensor dust.  |
ollie Moderator
Posted: Thu Aug 26, 2010 2:36 pm Post subject: |
@Marrea - Most DSLR cameras (Canon, Nikon, Pentax, Olympus and others) now have inbuilt sensor cleaners - they use ultra-sonic vibrations. I've not had a problem with my Pentax K-7
Back on topic, a great option for medium format cameras to produce massive, high quality prints. It's a pity they don't make medium format cameras - not that I could afford one if they did  |
Marrea LXF regular
Posted: Thu Aug 26, 2010 4:09 pm Post subject: |
| ollie wrote: | @Marrea - Most DSLR cameras (Canon, Nikon, Pentax, Olympus and others) now have inbuilt sensor cleaners - they use ultra-sonic vibrations. I've not had a problem with my Pentax K-7  |
Hi ollie
Yes, indeed, my three year old Canon EOS400D has a self-cleaning sensor unit which shakes dust from the sensor each time the camera is powered on and off. So where does the dust go once shaken off? It’s still floating around inside the camera ready to settle on the sensor again!! If these so called self-cleaning units actually worked effectively there would surely be no need for kits such as the Visible Dust Arctic Butterfly which sell at anything from £100 upwards.
You're very lucky if you've had no problems with your Pentax. I try to keep my lens changing to an absolute minimum, nearly always indoors, always keep the lens throat pointing downwards, and still I can spot dust blobs in my photos - usually seen in large areas of blue such as the sky. Nothing major yet and easily removed of course with Photoshop but irritating nonetheless.  |
LeeNukes LXF regular
Joined: Sun Jun 21, 2009 9:11 pm Posts: 954 Location: At the bar
leke LXF regular
Joined: Mon Oct 22, 2007 6:45 pm Posts: 479 Location: Oulu, Finland
