Crappy Ubuntu Sound
PostPosted: Tue Sep 14, 2010 10:55 pm    Post subject: Crappy Ubuntu Sound Reply with quote
Ok. I'm fed up with crappy distorted sound in Ubuntu. I've tried everything I know and a fair amount other people seem to think will work.
Is there a decent fix for the distorted sound I get playing music or some films?
Will installing this spare sound card I have help?
loebus
PostPosted: Tue Sep 14, 2010 11:45 pm    Post subject: Reply with quote
My laptop have really week sound and therefore connected to external 2.1 speakers.
Depending on what version of ubuntu you are using you could try PulseAudio System Wide Eq. to improve the sound
http://www.webupd8.org/2010/02/pulseaudio-system-wide-equalizer-now.html
That soundcard looks like a c-media which could output 5.1 which I had in my computer!
bobthebob1234
PostPosted: Wed Sep 15, 2010 9:59 am    Post subject: Re: Crappy Ubuntu Sound Reply with quote
heiowge wrote:
distorted sound
I assume you have tried the speakers with a different computer / os and they sound ok...
PostPosted: Wed Sep 15, 2010 10:41 am    Post subject: Reply with quote
I have sort of tried with different computer.
Basically, I've had crappy sound since 8.10, which I haven't been able to fix. I've changed to 64 bit when I got the new(er) PC, but have kept all the hardware, just changed tower.
Prior to changing to 10.04, the machine was dual booted with XP, which had no sound issues, so I have had no real reason to suspect the speakers.
***edit***
Just tried the pulseaudio equaliser, and it made the distortion worse.
PCNetSpec
PostPosted: Wed Sep 15, 2010 11:31 am    Post subject: Reply with quote
Which audio controller are you using at the moment?
Code:
lspci | grep audio
If the audio was OK in Windows, I'm guessing it's a driver issue with your current controller, so give the CMI8738 card a go and see if there is any improvement.
Linux in the UK
The Linux Community Forum
loebus
PostPosted: Wed Sep 15, 2010 12:58 pm    Post subject: Reply with quote
Have you tried changing the audio profile?
»Left click volume control
»Select Sound Preferences...
»Click Hardware tab
»Select a different profile
I have these in my profile:
Analog Stereo Duplex
Analog Stereo Output
Digital Stereo (IEC958) Output + Analog Stereo Input
Digital Stereo Duplex
Analog Stereo Input
Off « which obviously turns the sound off!
Hope this helps!
PostPosted: Wed Sep 15, 2010 2:46 pm    Post subject: Reply with quote
Code:
lspci | grep audio
Result: 00:14.5 Multimedia audio controller: ATI Technologies Inc IXP SB400 AC'97 Audio Controller (rev 02)
Ioebus - I have all those options and a few more. I have tried them all, but with no luck. At present, the best output comes from Analog Surround 4.0 Output + Analog Stereo Input
PostPosted: Sat Sep 18, 2010 10:52 am    Post subject: Reply with quote
Looks like I have no choice now. My sound drivers seem to have disappeared overnight (actually since I did ubuntu update!) Mad
PostPosted: Sat Sep 18, 2010 1:39 pm    Post subject: Reply with quote
Have a read of this thread . I use it on my laptop as sound is broken, only get it with headphones plugged in. The scripts fixes it and I can't complain about the quality.
PostPosted: Sat Sep 18, 2010 6:02 pm    Post subject: Reply with quote
Actually, the card fixed it. And solved the crappy sound as well. Laughing If only I could get VoIP working with my friend on Vista (which works connecting to my friend using Win7 Confused ), I'd be sorted!
PostPosted: Mon Sep 20, 2010 12:28 pm    Post subject: Reply with quote
Spoke too soon. I've had better sound, but it now tends to screw up part way through playing stuff.
Would reverting to Debian sort it, or is it a problem there also? How about Mint? I'd rather not switch from Ubuntu, but I need the sound fixed. Crying or Very sad
