Ubuntu 10.10
Goto page 1, 2, 3  Next
PostPosted: Mon Oct 11, 2010 6:38 am    Post subject: Ubuntu 10.10 Reply with quote
Anyone else tried it yet?
I left my HP2133 Mininote upgrading over night, seems to be running okay, though it'll have to wait until this evening for me to find out what else besides the wallpaper has changed.
bobthebob1234
PostPosted: Mon Oct 11, 2010 8:57 am    Post subject: Reply with quote
I have the alpha on my netbook, did all the updates not much changed. Going to install from strach this afternoon.
Does anybody know if the netbook release comes for 64bit?
PostPosted: Mon Oct 11, 2010 9:22 am    Post subject: Reply with quote
Only just got round to upgrading to Lucid on my netbook Rolling Eyes
M-Saunders
PostPosted: Mon Oct 11, 2010 10:12 am    Post subject: Reply with quote
Was playing around with the RC last week. Didn't get the funky new font by default though (had to enable it through the Appearance Prefs).
M
PostPosted: Mon Oct 11, 2010 11:36 am    Post subject: Reply with quote
I'm waiting on the all clear before upgrading. I had the screen flicker problem when I tried the Beta version, so I'm waiting to see if it's been fixed.
bobthebob1234
PostPosted: Mon Oct 11, 2010 11:48 am    Post subject: Reply with quote
Surely that involves trying it?
PostPosted: Mon Oct 11, 2010 12:11 pm    Post subject: Reply with quote
Not really. The flickery screen was a known bug. If people are trying it without having that problem, it must be fixed.
M-Saunders
PostPosted: Mon Oct 11, 2010 12:30 pm    Post subject: Reply with quote
Is it just me or are the window resizing controls ridiculously small? Maybe it was the case in 10.04, but I've always been using Xfce so I don't know. Open a terminal and try to grab the bottom-right corner to resize the window -- there's only a 1 pixel area to grab.
M
PCNetSpec
The ATI flicker thing?
If so... yes there are now working ATI radeon drivers for Xorg 1.9 built in (not included with the alpha)... my ATI graphics are now better than they were in Lucid.
I've been running the RC since it was released, and I reckon it's more stable than Lucid.
The high load averages displayed by Lucid (known kernel issue) are much improved... thanks to the 2.6.35 kernel... but still a bit higher than Karmic.
I'm quite impressed... from what I've seen so far, I'd say Maverick is what Lucid *should* have been.
Linux in the UK
The Linux Community Forum
MrsB
PostPosted: Mon Oct 11, 2010 1:43 pm    Post subject: Reply with quote
When I tried the beta, ten days or so ago, there was a problem with the grub installation (tried several times) which left me unable to boot the machine other than with a live cd.
I ended up installing 10.04 and am hesitant to upgrade. I did read at the time that an upgrade from 10.04 worked for somebody in the same situation, rather than straight install of 10.10 but some reading to do before I let it do its thing.
spaceyhase
PostPosted: Mon Oct 11, 2010 2:43 pm    Post subject: Reply with quote
Well, WOMM (works on my machine) although it did fail during the upgrade trying to install phpmyadmin (as it didn't have a database and didn't seem to know how to create one; so why the reconfigure/upgrade? Unknown) so didn't run through the 'clean up' step and 'reboot'. I had to do that bit manually... but it all works and there's some nice new fonts and styles, a little bit faster to use (or maybe it feels faster, hmm?). I'm an xfce user by the way so can't really comment on gnome desktop changes.
Although I'm still on grub. There's a chainload into grub2 option that doesn't work because I don't appear to have grub2 installed. I assumed that was part of the process as the option had appeared but I guess not. Is it fairly easy to install, e.g. like this?
http://www.ubuntu-inside.me/2009/06/howto-upgrade-to-grub2-on-ubuntu-jaunty.html
(which seems to make sense).
jamie_tickner
PostPosted: Mon Oct 11, 2010 9:58 pm    Post subject: Reply with quote
I put it on my nwtbook tonight and I don't like it.
The new panel/dock on the left is a bit confusing and the icons don't line up 100% properly.
The new default font is okay but the sizing seems to be huge compared to how I had under 10.04.
The top panel cannot be customised, when I launch a Ubuntu Desktop session as opposed to a Ubuntu Netbook session the top panel is not there at all and it is basically the netbook edition minus top panel, not the classic ubuntu desktop.
Will take time to get used to me thinks... on the plus side it runs quicker imo
hecatae
PostPosted: Tue Oct 12, 2010 9:00 am    Post subject: Reply with quote
installed at 1am on the 10th October, nice to see the Plymouth issue resolved on my 10in netbook, installed Desktop Edition not Netbook Edition, as Unity is unusable, far too slow
spaceyhase
PostPosted: Tue Oct 12, 2010 9:24 am    Post subject: Reply with quote
I went ahead and changed to grub2. Fairly easy overall despite the cold sweat induced by synaptic when it says it's going to remove 'grub' before it has installed grub2.
There's a 'grub2' dummy package for upgrades and the whole thing is guided by the install configuration. One can chainload into grub2 to test and then, when it is all working, just enter the upgrade command (which is handily put into the old boot menu!).
It's not any faster though but YMMV.
PostPosted: Tue Oct 12, 2010 12:32 pm    Post subject: Reply with quote
After being told by a load of people that the 10.10 screen flicker issue was sorted, I upgraded. It flickers. About once every 3-4 seconds. Crying or Very sad
I tried the ATI site. They gave a driver that doesn't run.
I'm gonna use Win7 for a week, then update. If it's still not fixed, I'm gonna reinstall 10.04. Crying or Very sad
Page 1 of 3
