Chrome puts itself on Startup Applications
bobzr
PostPosted: Thu May 10, 2012 9:15 am    Post subject: Chrome puts itself on Startup Applications Reply with quote
I don't know if this happened with Oneiric, but since I installed Precise I have noticed that Google Chrome put itself on my Startup Applications. Processes like "chrome-no-startup-window", "chrome-sandbox", "chrome-type-zygote", etc. keep on running on the background. If I remove Chrome from my Startup Applications, it will show back next time I start the computer. Does anyone else noticed this? Any idea on how can we stop Chrome misbehaving like this?
PostPosted: Thu May 10, 2012 11:23 pm    Post subject: Reply with quote
I have chromium installed and a quick look through my running processes shows none related to chromium.
So it looks as if it is an issue with the chrome packaging.
bobzr
PostPosted: Fri May 11, 2012 7:03 pm    Post subject: Reply with quote
Thanks for your feedback. I'm going to replace chrome with chromium and see what happens.
I double-checked and can confirm that every time I launch Google chrome, it puts an entry on the Startup applications. On next startup it will start many hidden chrome-xxx processes and sometimes will start using my bandwidth downloading who knows what...
Very bad behaviour, it reminds me MS viruses. Evil or Very Mad
lok1950
PostPosted: Fri May 11, 2012 7:37 pm    Post subject: Reply with quote
It's probably telling Google all about you Twisted Evil and if you check the fine print on Chrome's eula it might even mention it.
Enjoy the Choice Smile
bobzr
PostPosted: Tue May 15, 2012 6:43 pm    Post subject: Reply with quote
OK here's what happened. There's a choice on the "Under the hood" options of Google chrome /chromium where you can allow google apps to run in the background. I have unticked that and now everything is fine! Very Happy
[SOLVED]
