Monodevelop Runtime 2.0 doesn't complie
moeFinley
PostPosted: Sun Jan 28, 2007 4:53 pm    Post subject: Monodevelop Runtime 2.0 doesn't complie Reply with quote
I using Edgy and Monodevelop 0.12
I have an application that compiles and runs fine using runtime version 1.1 but as soon as I switch to 2.0 it would create an .exe
There are no errors when it compiles but when I try and run it I get
Code:
cannot open assembly
and there is not .exe in the output folder?
I'm just starting to learn Mono so I'm sure I might be doing something wrong but I don't know what. Could any help shed any light? Thanks
tjelle
PostPosted: Fri Feb 02, 2007 5:20 pm    Post subject: RE: Monodevelop Runtime 2.0 doesn Reply with quote
I got the same problem (ubuntu 6.10 edgy), when trying out the mono tutorial in LFX88.
Was wondering if it had to do with the version of mono installed on ubuntu: mono (1.1.17.1-1ubuntu7.1)?
Does anyone know?
moeFinley
PostPosted: Fri Feb 02, 2007 6:57 pm    Post subject: Reply with quote
Sorry, someone posted the solution on the Ubuntu Forums and I should have duplicated it here. You need to install the 2.0 complier.
Code:
sudo apt-get install mono-gmcs
Here is a link to the Ubuntu Forums Post
http://ubuntuforums.org/showthread.php?t=348140
Hope this helps
tjelle
PostPosted: Sat Feb 03, 2007 1:05 pm    Post subject: Reply with quote
Thanks, it works now. Smile
